Minneapolis Moline Tractors Discussion Forum
3 point leaks down M5
Superpicker
10-21-2006 07:04:05
On a early M5, the 3 point hitch will leak down on its own, such as hauling a round bale (750 lb.) or hauling a bush hog, within 15 minutes, it will drop a few inches. Overnight when shut off and no 3 point load and when the arms are up, they will be completey down by morning.
What to suspect is the problem to check? Thanks
mrp
11-02-2006 14:40:52
 Re: 3 point leaks down M5 in reply to Superpicker, 10-21-2006 07:04:05
seems like a normal condition on Molines...note I didn"t call it a problem ;)
JK2
10-21-2006 15:54:59
One or more of the following:
1. The seals on the piston are not very good
2. The cylinder is scored
3. The spools are not syncronized properly
To check is is is the spools, hold the 3 point lever either forward or backward slightly and watch to see if the system drifts slower. If it doesn't the problem is likely in the cylinder.
John
