Minneapolis Moline Tractors Discussion Forum
335 2428 Rear Wheels?
Mopower
10-20-2006 09:13:23
My 335 has a nice set of 24" wheels with the 6-bolt pattern. Other folk"s 335s have 28" wheels. I"d like to find the scalloped 6-bolt centers fit my good 28" rims. Which size was more common? I know 28" was optional according to my sales literature. All 445 and Jet Stars had 8-bolt wheels. I got a pile of them.
Thanks,
Ethan
shinnery
10-20-2006 23:07:25
 Re: 335 2428 Rear Wheels? in reply to Mopower, 10-20-2006 09:13:23
"All 445 and Jet Stars had 8-bolt wheels" ????
Both my 445s have 9 bolt 38s on the back and one has 6 bolt 16s on the front. The other is a 445N.
Bryce
Mopower
10-24-2006 06:36:24
 Re: 335 2428 Rear Wheels? in reply to shinnery, 10-20-2006 23:07:25
Only the utility models.
JK2
10-20-2006 20:20:08
My 335 Utility came with 28's on it. My 335 Industrial w/Ottawa backhoe & loader also has 28's on it but they have 12 holes and bolts in them instead of 6. Most of the 335's that I have seen that had 24's were ones that were used for mowing along highways. You could weld a piece on each star point and drill new holes.
John
mowr
10-20-2006 18:47:06
By far, most of the MM 335 utilities I've seen had 24" wheels and all the Cockshutt 20's I've seen had 24's.
T.R.K.
10-20-2006 17:20:29
Can only say that my 335 utility has 24" wheels. (Power adjust rims)Right now it has 12.?-24 Safemarks on them. This makes the tractor itself almost as large as the Jetstar it is parked beside.
I've never seen a 335 utility with 28" tires.
To make the swap you may have to look at some other make rims like from an Allis Chalmers. That is where I got one wheel center (Allis CA). The original was warped.
Mopower
10-24-2006 06:42:02
 Re: 335 2428 Rear Wheels? in reply to T.R.K., 10-20-2006 17:20:29
It has 24" Allis CA wheels. Nice but too small. It was used as a county mower tractor. Can't find a smal 6-bolt Allis with 28" wheels. Moline BF will work.
