Minneapolis Moline Tractors Discussion Forum
Moline R belt pulley
Loren in MN
10-16-2006 11:26:09
I'm mounting a pulley shaft housing to a "R" Moline. I was expecting gear grease to pour out when opening the cover. Like would happen if pulling the housing off of a "Z". The sump area where the pulley drive bolts on had only about a cup of grease and the plug for checking the rear end grease seems to be below the pulley mounting area. Should the pulley drive be submersed in oil? How would this be filled? Or is it supposed to be dry? The manuals I have don't say anything about checking or adding grease to this area. Can anyone help? Thanks, Loren
Jim Parisot
10-17-2006 10:56:31
 Re: Moline R belt pulley in reply to Loren in MN, 10-16-2006 11:26:09
Loren,
That compartment is indeed above the gear oil level in the transmission compartment and relies on gear splash to bring the lubricant up to it. Just inside the compartment on the left side you can see and feel two holes. The upper one is a trough to catch the oil on the transmission side of that cast dividing wall and brings it to the belt pulley compartment. The bottom one is simply the drain back hole and maintains the proper level. Simple, but very effective. Hope this helps.
Jim
