Minneapolis Moline Tractors Discussion Forum
JAHNS PISTONS FROM WELTERS
UB-ToMMy
10-12-2006 19:06:37
I bought a set of the Jahns pistons from Welters. They are 4.375� +0.060� over. ie. essentially a 3/16� overbore. The thing to be careful about is to make sure that when the blocks are rebored the recommended diametral clearance between piston and bore is maintained. As I recall .008� is recommended. Initially my blocks were mistakenly rebored with a 0.006� clearance. The result was disastrous. The engine would seize when run wide open for any length of time. I thought and hoped the problem was something other than the pistons. Upon disassembly, I found #1 piston severely damaged well beyond usability. The others were fine. I was able to buy one more piston from Welters�it was their display piston from the counter. I had to machine a substantial amount of the inside of the skirt to make it match the other 3 in weight and I fine tuned the weight so that all 4 weighed within about 3 grams of each other. One other thing, I had to machine the wrist pin boss openings on the inside so that the rod would fit between the two bosses on all 4 pistons. I had the bores honed to give 0.010� diametral clearance except for the bad hole which was machined 0.012� over. I wasn�t too concerned about piston slop since the tractor use was for pulling not field work.
I also have 4207 heads on the tractor. With the Jahns pistons and the high compression heads I�ve finally gotten the engine to the point where it doesn�t power out-at least not easily. After 3 years of trying to get it right, this year was the payoff in that the tractor was 1st place successful in a number of pulls. And, by the way, it never, never overheats and barely gets into the run zone when run without a thermostat. One other point: it runs best on race gas.
