Minneapolis Moline Tractors Discussion Forum
ZB compression
ILLMolinepullers
10-11-2006 18:02:04
Does anyone know the compression for a 1953 Moline ZB.
ILMolinepullers
10-14-2006 17:53:50
 Re: ZB compression in reply to ILLMolinepullers, 10-11-2006 18:02:04
Yes...I am interested in purchasing your 2648 head, will email you with contact infomation.
PGpower
10-12-2006 06:58:42
If you go to this website, there is some info about Moline head specs. It has some info about 206 engines, with different heads on them.
take a look and see if it has your cylinder head listed.
http://members.tripod.com/~Fiorelli/
ILLMolinepullers
10-12-2006 18:09:40
 Re: ZB compression in reply to PGpower, 10-12-2006 06:58:42
PGpower thanks for the info. Already had all that from the web site. Doesn't give me the compression at cranking speed for my ZB with a 206 motor.
Augie
10-12-2006 18:26:34
 Re: ZB compression in reply to ILLMolinepullers, 10-12-2006 18:09:40
Which cylinder head do you have?
On a fresh rebuild with Welter's pistons mine pumped 165psi with the 48 head.
ILLMolinepullers
10-13-2006 18:22:01
 Re: ZB compression in reply to Augie, 10-12-2006 18:26:34
Augie...Do you mean you have the 10A2648 head, I have the RE226C on mine and is yours better. Need to get more power for pulling.
RDD
10-14-2006 06:55:36
 Re: ZB compression in reply to ILLMolinepullers, 10-13-2006 18:22:01
Yes,2648 head is much better head.You will need all the help you can get pulling these engines. I sold Augie his head and have one on my pulling tractor. Will sell it,if your interested,not going to pull the tractor next year.
ILMolinepullers
10-15-2006 10:57:55
 Re: ZB compression in reply to RDD, 10-14-2006 06:55:36
Yes...I would like to purchase your 2648 heads, I will email you with info.
Augie
10-15-2006 10:06:03
third party image
Roger that! Mine showed 52hp @540pto on the local ACGO store dyno right after it was built, should be a little better than that now that it's broken in. Not bad for less than $1000 invested in the engine. It's got plenty of motor up to 4500lbs outdoors. The 4000 is a load for it indoors.
