Minneapolis Moline Tractors Discussion Forum
U 302 no hdy. no pto .no ampitoque help!!!
Scott Mullinax
10-10-2006 21:08:03
Ihave a u302 super that the hyd. ,pto ,and toqre has quit. need help
SWMolines
10-11-2006 08:37:26
 Re: U 302 no hdy. no pto .no ampitoque help!!! in reply to Scott Mullinax, 10-10-2006 21:08:03
Did this all happen at once?
The PTO and hyd. are driven off a common shaft that runs from the flywheel to the rear of the tractor. I have seen tractors where the drive spline wears out at the flywheel end of the shaft causing the lost of PTO and hydraulics. It could be either male or female spline that fails.
As for the torgue, you'll have to give a little more information. Does it not work in either hi and low range? Does it the handle snap into position for hi range? ..... .
