Minneapolis Moline Tractors Discussion Forum
Winter Projects - What are you working on?
SWMolines
10-09-2006 13:54:49
Okay! It is that time of year again. Time to start thinking about those winter projects. What is everyone going to be working on.
Me? I am hoping to get back onto my 2 Star loader. I got side tracked this year by a UTN,a Jet Star, a 1960 Ford F 250 Crew Cab, a Moline BF, a 602 Diesel, tumbleweeds and butterflies. With all the distractions out of the way, I will hopefully get back to the 2 Star.
With all the auctions I saw listed this summer people must have picked up a lot of MMs needing TLC.
sssss
10-12-2006 19:17:03
 Re: Winter Projects - What are you working on? in reply to SWMolines, 10-09-2006 13:54:49
Someone gave me an old (1948) D7 that I want to get purring then finish my 48 RTE. Y'all work safe out there so we can keep hearing from you here
UB-ToMMy
10-12-2006 07:47:59
Well SWM, since I missed out on that 2 Star Crawler in PA earlier this summer, I will continue work on my early 670 and UTC. And, if time permits, I�m going to shoot for redoing a ZB and ZTS�early boyhood tractors done for old time sake.
The Dukester
10-11-2006 08:22:42
Gonna clean up and paint the old '47 UTU...oh, and change the leaking right axle seal. Gotta make the old Minnie purdy, she's such a good runnin' ol' hoss. Then I guess it's back to the Johnny Poppers and get the '48 A's block bored out to whatever cleans up the pits in no. 1 cylinder and some new 6.5 to 1 oversized alummy pistons put in it...and get the head faced off about .060 or so. Gotta get a little more pep out of the old Putt-putt.
Red Tech
10-10-2006 19:20:46
Hehe, I'll probably be working on a bit of everything. I have a 1953 UTS that needs a little tuning and fixing before it can hit the stock pulling circuit next summer. I might put the flywheel back on my John Deere 70 diesel standard, and maybe fix the pup motor. If I have time, I might also do an engine rebuild on my Ferguson TEA20. Oh, and I should tinker on my 1953 Mercury 2 ton truck.
No shortage of projects for the next couple years. :-)
T.R.K.
10-10-2006 18:23:48
I am working on a Big MO 400 Military. As soon as I get the brakes working I think I will put the clutch in my ZAS and straighen out the hydraulics. Then there is the other ZAS with orchard tin that needs a zillion hours of body work.
Then there is that Mocraft that mainly needs rings and paint. . .
I guess I have project deficit disorder. Almost all of them are running but need "one more thing"-and THEN paint.
PGpower
10-10-2006 17:17:31
just going to work on making some more weight brackets for my U puller, and maybe make an adjustable hitch for it too. Not going to be a lot of shop time this winter, as the wife and i are having our first child in december...wife thinks i should be changing diapers instead of 'working on that dumb tractor'!!
Mopower
10-10-2006 09:02:19
Looks like I have a 206 R and a 403 U that need to get finished for good as well as button up a few details on a 335 and 5-star. Finish gathering my pile of G parts and at least assemble a rolling JTU out of pieces. We"ll see...first things first... CLEAN THE SHOP!!!
Molinegb
10-10-2006 05:15:32
Hope to finish 39 and 40 UTS in the next couple of weeks. 1940 GT will be my next project for the winter.
BMG1
10-09-2006 19:15:46
I hope to make more progress on our UBED this year than I did last year. Its been in the shop going on 6 years or more now shoved back in a corner. It's completely disassembled but I did get the differential and trans gears back in it this summer. Spent the last month rearranging the shed to fit in all the additions from the past 6 months. Came to the terrible realization that I've got to sell some (ZBU and 2 RTIs) to make room for the latest additions.
Brian
Newtothisgame
10-09-2006 17:13:10
im going to finish my Little genius plow assembly do some fixing on my moline plow and tweek the Zau a little and mabey start on that ls300 manuer spreader
ILL John
10-09-2006 16:51:47
I'm gonna try to get on my GTB/LP, take off 4209 heads, put on 4210 heads, take off mag, install waterpump shaft, distributor, hyd pump and hyd system along with a new radiator and a Behlen power steering unit. Wanna make the plow days interesting in a bigger way and make it easier on my arms, lift the plow with 1 finger, turn the steering wheel with 1 finger.
farmerjosh
10-09-2006 15:16:37
gonna put a 403 in one of my UB's, and finish up my Dads R. also have a few plows to get ready for plow day, and an H farmall to paint for my little daughter
willywonka
10-09-2006 14:00:32
gonna try a ol gb this year. hope to have it out for next years pulling season
