Minneapolis Moline Tractors Discussion Forum
335 Utility ?
LW
10-04-2006 21:30:57
Where the steering arms hook up is there a dovetail mount like the other molines, And if so will one of the other try type dovetail fronts mount there? ex.445? Any help appreciated not many of these in my area/
10-10-2006 18:12:55
 Re: 335 Utility ? in reply to LW, 10-04-2006 21:30:57
Give us a call, we have two 335 front castings with dovetail steering mount, 920 295 3278 or email [email protected]
JK2
10-05-2006 06:22:33
Not only is there no dovetail mount on the 335 utility, there is also no place in the front casting for a top bearing. Or at least on any of the ones I have seen. If you are looking to mount a tricycle front on it, you can use a front casting from a 445 to get the top bearing mount but you need to do a bunch of cutting and grinding to get rid of the lower radiator tank etc. There are other ways to get even lighter with the front end.
John Kinsey
T.R.K.
10-05-2006 05:56:12
No, there is no dovetail mount on the 335 Utility bolster. There is just an arm the tie rods hook to. I doubt that the bolt holes are in the right place for the pivots from a wide front either.
But I am guessing you want just a narrow front for 'pulling.
LW
10-05-2006 18:17:54
 Re: 335 Utility ? in reply to T.R.K., 10-05-2006 05:56:12
Yeah I want to put one together for the stock classes I just want it to look like a row crop, and finding one of those is about out of the question.
