Minneapolis Moline Tractors Discussion Forum
Minneapolis Moline Cylinder Heads
Lighty
10-04-2006 09:58:01
Can you change cylinder heads on the minneapolis moline engines without changing any other internal parts to gain better air/exhaust flow and ultimately some more horsepower? If you what head changes do you recommend for increased performance?
Glen in TX
10-10-2006 15:46:16
 Re: Minneapolis Moline Cylinder Heads in reply to Lighty, 10-04-2006 09:58:01
Sure you can but just depends on what engine it is now and what's on it now and what piston you are running. Tell these guys what tractor or engine and they'll have recommendations for you. There were higher compression LP heads.
Lighty
10-11-2006 06:00:50
 Re: Minneapolis Moline Cylinder Heads in reply to Glen in TX, 10-10-2006 15:46:16
The engine is the 425ci Minneapolis Moline diesel with 4 1/4" bore and 5" stroke. Will the 10A4222 heads fit directly onto this motor without having to change the bore of the engine? Does the 10A4222 heads have larger valves? Will this modification add horsepower?
