U rotary ignition switch
Knute
12-06-1999 18:13:39
Can anyone help with the connections for a rotary ignition switch? I have a MM U S-158 rotary ignition switch. The switch positions are:
OFF
START
START & DIM
START & BRIGHT
LIGHTS ONLY
When viewed from the back the switch has two connections (A and B) with a coil connecting them. Then there are four connections below the A and B connections (C, D, E, and a curve shaped piece F)
.....A.....B..
..... ..... ..... C....D....\...E..
..... ...F.... When I ohm the switch out, I get inconsistent results. Does anyone know what the connects are? My manuals (parts, service, and operators)for the S-158 do not have this info.
Thanks.
Bill Becker
12-06-1999 20:28:56
 Re: U rotary ignition switch in reply to Knute, 12-06-1999 18:13:39
According to Manual S-119C, the 5 position switch is wired as follows: The wire that connects to the top of the curved piece goes to the voltage regulator terminal marked with an "L". This is the terminal closest to the pulley, or the front of the tractor.
The left side of the colied wire is hooked to the fuse holder and the right side is hooked to the dash light. The coiled wire is a resistor that is activated when you switch the lights from bright to dim. Minneapolis Moline marketed this feature as split beam headlights, but in reality, they added this resistor to reduce the voltage to the headlights.
The wire that hooks to the terminal to the left of the curved piece goes to the positive side of the coil. (Assuming you have a positive ground system. If you converted this to negative ground, this wire would go to the negative post on the coil.
The other wire coming out of the fuse holder goes to the headlights. This wire should have an in-line disconnect.
The right side of the ammeter gauge goes to the starter selenoid and is hooked to the same post as the battery cable. The top terminal of the selenoid goes to the left side of the starter button. The right side of the starter button also hooks to the right side of the ammeter gauge.
The left side of the ammeter gauge goes to the middle terminal of the voltage regulator.
I have a wiring diagram that I send you a copy of.
