Minneapolis Moline Tractors Discussion Forum
ALUMINUM U PISTONS
Tom Peterson
09-27-2006 22:00:48
I put a set of Jahns aluminum pistons in my UB. Got them from Welters. Seems like the objective was to try to get them all to weigh the same so that any imbalance would be slight. I used a gram scale to get them all to within about 5 grams of each other. Tractor seems to run fine like that---no strange vibrations or anything. Of course, I�m only turning about 1500 RPM wide open and the tractor is only used for the occasional tractor pull. If the RPM was double that, balancing may be warranted.
One other thing. Make darn sure you leave enough diametral clearance between the aluminum pistons and the cylinder walls. Welters recommends .008� for the Jahns pistons. Mine were originally and mistakenly done at .006�. The result was nasty. When redone, I had the clearance taken out to about .010� and that works great.
