Minneapolis Moline Tractors Discussion Forum
1939 U torque specs
molinegb
09-25-2006 08:13:32
Do anyone know the torque specs of the babbit rod bearings? I put the original rods and original shims back in but won"t set up properly. I"m torquing to 75 lbs.Any ideas?
Fungus
09-26-2006 15:42:59
 Re: 1939 U torque specs in reply to molinegb, 09-25-2006 08:13:32
The manual says between 80-85 ft.lbs for the rod bearings and for the mains: Front 110-120ft.lbs Center and Rear 75-80ft.lbs.
Now maybe you can help me! What are the specs for the crankpins on your old U? I got a KTA (283ci), same as the U with babbitt bearings in it and would like to know the specs. I'm not sure if they would be the same.
Hope I helped you.
