Minneapolis Moline Tractors Discussion Forum
MM 206 power unit
R Moline
09-24-2006 09:03:51
I have a 206 power unit that has hydraulic lifters. I have been told that this is farily rare. I am wanting to put a 206 in my R and I do not want to use this motor if someone else is in need of it. If anyone is interested in it I would sell it if I could find another one. What is something like this worth? Thanks
BMG1
09-24-2006 15:31:16
 Re: MM 206 power unit in reply to R Moline, 09-24-2006 09:03:51
Where is engine located? Has a lot to do with price.
R Moline
09-24-2006 16:38:14
 Re: MM 206 power unit in reply to BMG1, 09-24-2006 15:31:16
the engine is located in middle tennessee
BMG1
09-25-2006 13:57:34
 Re: MM 206 power unit in reply to R Moline, 09-24-2006 16:38:14
If its stuck $50-$150 depending on overall condition. Good running condition $400-500 or so. Just my opinion. If it were closer to Michigan I might be interested.
R Moline
09-25-2006 15:37:03
 Re: MM 206 power unit in reply to BMG1, 09-25-2006 13:57:34
Thanks it does not run but is not stuck and is complete minus starter and dist.
T.R.K.
09-26-2006 17:09:03
 Re: MM 206 power unit in reply to R Moline, 09-25-2006 15:37:03
FYI: Most likely it had a magneto. Check if the mag/dist. drive flange on the crankshaft turns 1/2 turn or a full turn every revolution of the crankshaft. If it turns a full turn the engine had a magneto. If it only turns 1/2 turn, its set up for distribuitor.
R Moline
09-27-2006 14:41:11
 Re: MM 206 power unit in reply to T.R.K., 09-26-2006 17:09:03
Is there anyway to change it??
