Minneapolis Moline Tractors Discussion Forum
M5 Ampli-torc
Wayne in Iowa
09-23-2006 19:29:35
Have helped a good friend keep his 4 MMs tractors running mechanicly. Split his M5 for a clutch and found oil leaking from the tranny. Remove the input shaft cover to replace the seal. Hind site tells me I should have applied the ampli-torc before removeing the front cover. I know, should have had a service manual but that is water over the dam,too, now.How do I get the torc discs back into the housing? Shoulda stuck with my Fords!Oh, shouldn't have said that here!! Sorry! Please help!!!
Captainhookerus
09-24-2006 08:47:42
 Re: M5 Ampli-torc in reply to Wayne in Iowa, 09-23-2006 19:29:35
Go ahead and knock the roll pins out of clutch forks and remove torq engaging shaft. Pull assembly out and put discs back in before you bend any of them.. You will save time if you have another hub to help line up discs.
Wayne in Iowa
09-24-2006 09:35:15
 Re: M5 Ampli-torc in reply to Captainhookerus, 09-24-2006 08:47:42
Thanks for the quick responce and answer to the problem . Access to another hub is probably slim to none around here, but we will get her one way or another. Thanks again.
Captinhookerus
09-24-2006 11:26:26
 Re: M5 Ampli-torc in reply to Wayne in Iowa, 09-24-2006 09:35:15
Wayne you might give some thought to putting in new springs and rollers in the one way sprag clutch. Just don't get you wrench caught. This would be a good time to replace the oil with universal hyd trans oil. The Ampli-Torq works a lot better with this oil.
