Minneapolis Moline Tractors Discussion Forum
u engine build
cds
09-22-2006 16:25:28
I am thinking about putting a 403 crank in my 283. What do I have to use for rods, and pistons. I know that the crank will fit in the crankcase. Any info would really be appriciated.
Thanks
cds
09-23-2006 16:51:29
 Re: u engine build in reply to cds, 09-22-2006 16:25:28
Does offset grinding go through the hard surface of the crank? Or do they have to re harden it.
Were can you get a crank offset ground. I live in north central Nebraska.
Mopower
09-23-2006 09:46:37
If you are staying with stock blocks, use U rods and offset grind the crank to fit the U rod journal size (smaller). Not sure if they make an overbore piston for this, but most use the larger M5 blocks for which a piston is available from Welters Farm Supply that compensates for the increased stroke.
