Minneapolis Moline Tractors Discussion Forum
Big mm
Ricky in arkans
09-22-2006 04:53:10
I bought a big M M tractor, 4x4,diesel, 5speed, bends in the center to steer, 3 point lift ,no pto,cab,and it is red.
how can i find the year and model????? there is no numbers that I can find???
BMG1
09-22-2006 06:13:14
 Re: Big mm in reply to Ricky in arkansas, 09-22-2006 04:53:10
Ricky,
Sounds like you've got an A4T 1400 or 1600. The serial # tag is located on the left side of transmission under the cab. A4T-1400 had the 504 diesel. A4T-1600 had either the 504 LP or 585 diesel engines. The 1400 was made from 1969 to 1970. The 1600 was made from 1970 to 1972. There should also be a tag on the side of the engine that we can use to tell you the model and year based on the above info.
Brian
Ricky in arkansas
09-22-2006 08:10:49
 Re: Big mm in reply to BMG1, 09-22-2006 06:13:14
Thank you
I found the tag . It is an A4T1400 with a D 504 motor.Ser# 4390076. Now where is the best place to buy rebuild kits ???
BMG1
09-22-2006 17:57:01
 Re: Big mm in reply to Ricky in arkansas, 09-22-2006 08:10:49
Complete rebuild kits generally are not available for most MM applications. Your best bet would be to check with your local AGCO dealer to see if they can get Moline parts. Or give Welters a call in Verona, MO at 417-498-6496.
Brian
