Minneapolis Moline Tractors Discussion Forum
STUCK UTU
LAZY RAY
09-21-2006 22:33:25
Well boys I finally done it. Let my ole u soak in every snake oil mixture known to man kind and she would not budge at all. So me and my dad tore her down today. Thoes pistons must be really stuck bad. Going to have to drill holes in them and bust them out or try and press them out. But gonna do a over bore anyways. Thinking about pulling her and really putting the EAST TENNESSEE OLIVER boys in their place. What do you guys suggest? As far as heads and overbore limits and all?
Anderson
11-29-2006 12:00:18
 Re: STUCK UTU in reply to LAZY RAY, 09-21-2006 22:33:25
Was just wondering if you got the pistons out ever and if you tried the brake fluid and a match?
Anderson
09-24-2006 18:40:05
No it doesnt do any damage to the cylinders and also to get it to ignite better use a little torch to get it to start burning better.
dlp
09-23-2006 19:04:05
A post & sledge hammer works pretty well.
MNM45665
09-23-2006 07:14:55
If you are gonna mess with them olivers you better have at least a 5.5 bore and a 7 inch stroke with really good heads and manifolds.
Anderson
09-22-2006 15:31:33
No joke. We did it to the block of a MM JTS. Those pistons were stuck! So we put 1/4" of brake fluid in the cylinders and put a match to them. Brake fluid won't explode, it just slowly burns. We put it outside over night and in the morning it was still warm, and the pistons slid right out. The heat allows the brake fluid to work in around the pistons. It's pretty amazing. Let me know if you try it or not.
Lazy Ray
09-22-2006 16:23:35
 Re: STUCK UTU in reply to Anderson, 09-22-2006 15:31:33
Anderson, Would this work with the blocks still on the tractor and then trying to pull the stuck tractor in high gear and break them loose that way?
Fungus
09-22-2006 16:15:02
Never heard of that solution for stuck pistons before! Would the cylinder block suffer any damage? Or is this used just in extreme cases where an overbore will be done afterwards?
PGpower
09-22-2006 13:03:41
If your going to make a puller out of it, throw those blocks and pistons away and get some M5 (or equivalent) 4 5/8 in bore blocks. They will fit right on your U and give you a lot more cubes than just boring the U block.
Lazy Ray
09-24-2006 21:33:22
 Re: STUCK UTU in reply to PGpower, 09-22-2006 13:03:41
PG, YOU GOT ANY M5 BLOCKS YOU WANNA SELL ME ?
Anderson
09-22-2006 11:22:35
Now that you have it taken apart. Did you try putting about a 1/4" of brake fluid in the bores and then putting a match to it? It works pretty good.
Lazy Ray
09-22-2006 15:20:40
 Re: STUCK UTU in reply to Anderson, 09-22-2006 11:22:35
Anderson. are you kidding me? no joke?
