Minneapolis Moline Tractors Discussion Forum
rim centers
Ky-Tom
09-21-2006 07:24:12
Anyone ever made some weld in rim centers that fit a GVI 8 bolt hub ifso what thickness was the metal used for the centers ?
Andy2
09-21-2006 08:10:12
 Re: rim centers in reply to Ky-Tom, 09-21-2006 07:24:12
We did it for a U, we used 3/8" because we had some big enough pieces laying around. 3/8" should be fine for a GVI. 1/4" would work but you might want to have an additional ring around the bolt holes and perhaps some gussets welde on the inside to prevent flexing. 9 bold wheels are 3/16" and 1/4" inch thick but they get much of there strength from the dish. A flat plate would flex more. If you want 38" cast centers, you can use U 8 bolt centers and widen the rims out. They are a lot lighter than MM 34" centers.
