Minneapolis Moline Tractors Discussion Forum
Spraying Red Oxide Primer
Bog
09-21-2006 05:14:06
I bought a gallon of Red Oxide Primer from my local farm store i want to spray it on my tractor. However the can does not say what to thin it with. I called the paint manufaturer to find out and they said they were not allowed by law to suggest thining of this specific product. I was wondering what any of you guys use.
445
09-22-2006 01:09:51
 Re: Spraying Red Oxide Primer in reply to Bog, 09-21-2006 05:14:06
If it is lacquer based almost any lacquer thinner is ok. If it is enamel, epoxy or urethane then you need to use the manufacture recommended primer thinner. There are also water based primers that, at least the ones I have used, do not require thinning. Many of the other primers spray right out of the can. The high solids primers spray quite thick and allow heavy sanding to remove imperfections. Also it is important that the primer is compatible with your top coat. A good primer with a coat or two of a high quality sealer and a high quality top coat that are all designed to work together will give you a real quality paint job.
Tom Peterson
09-21-2006 18:43:09
Lacquer thinner is pretty typical. Mineral spirits may apply to some paints. High grade automotive paints usually demand a dedicated thinner.
