Minneapolis Moline Tractors Discussion Forum
OIL SPECKS
LARRY CHILDERS
09-19-2006 10:09:11
I have a 1961 m5 modle 336-4,I"am looking to find the Lubracation spec"s. For the engine,Trans,and Hidrolic system.The weigth,Type Or best brand.I"am restoring this great old war horse.We are down to the fliuds and filters thank you for the help. Larry
shinnery
09-19-2006 22:19:27
 Re: OIL SPECKS in reply to LARRY CHILDERS, 09-19-2006 10:09:11
You may want to consider a Diesel rated motor oil. I understand with the wide spread of roller lifter camshafts in cars and light trucks the EPA has been after oil manufacturers to cut back on the additive package in automotive oils to reduce pollution. Most big diesels still run flat tappets and their oils have all the additives.
Bryce
T.R.K.
09-19-2006 19:40:26
These are my opinion: Its what I've got in Mom's M5.
Engine: 30wt. HD (My opinion. I live in NC. If you live where its real cold you may want to try a multi-weight like 15w-40. Don't go too thin, these engines get 'knockified' when the oil is too thin.
Transmission: 90wt. GL1 (I've been told GL5 is harder on the brass busings in the transmission, although GL5 should otherwise be a better lubricant.)
3 point (Tel-O-Flo system) Dextron 3 (Original was Type 'S'. Dextron 3 I am told is the modern equivalent. Some guys who use their MMs with other brand tractors and equipment run Hytrans in the 3 point with no problems.)
