Minneapolis Moline Tractors Discussion Forum
Rear seal
bummed out
09-11-2006 16:06:10
Just test drove (breaking in) my new puller A za stock just rebuilt. Hour or eo into my drive stopprd to check fluid levels and the rear main seal is dripping oil out the hole in the bellhousing. Can I replace the oil seal with-out removing the crankshaft?
Thank You
T.R.K.
09-11-2006 18:01:59
 Re: Rear seal in reply to bummed out, 09-11-2006 16:06:10
Yes. But you have to split the tractor and remove the flywheel. The rear seal is in an sheetmetal holder bolted to the rear main carrier.
Tip: if the seal area on the crankshaft is fluted (has a spiral groove in it) you must use a felt seal as a replacement. A rubber lip-type seal will never work with that crank.
You musta had someone else rebuild your engine.
