Minneapolis Moline Tractors Discussion Forum
MM Generator Problem
MM Generator Pr
09-11-2006 10:18:41
The charging system (with generator) on my Jet Star goes loco when I rev the engine above a fast idle. It seems that once I get to about half engine speed, the amp guage needle starts jumping between charge and discharge.
Anyone have an idea what is causing this?
Alan K
09-11-2006 22:13:34
 Re: MM Generator Problem in reply to MM Generator Problem, 09-11-2006 10:18:41
That sounds about right with the regulator. Possilby it could be from vibration also in the regulator if the field doesnt have enough "pull" to hold the contacts together.
T.R.K.
09-11-2006 18:07:48
My guess is the contacts are sticking in the regulator. Or the regulator has other problems. But its just a guess.
