Minneapolis Moline Tractors Discussion Forum
1955 ZB
C Davis
09-11-2006 05:14:14
I need to see a wiring diagram not really just routing for the wires from the dash out across motor
T.R.K.
09-11-2006 18:12:05
 Re: 1955 ZB in reply to C Davis, 09-11-2006 05:14:14
If you want routing, the wires go through a rectangular conduit under the gas tank to the front mount, then they jump down and run across the top of the water manifold on the side of the block. Sheetmetal tabs on the upper water manifold bolts hold them in place. They circle around the front of the engine between the front block and the distribuitor to the coil and the generator.
