Minneapolis Moline Tractors Discussion Forum
Oil pressure
jenks britt
09-09-2006 11:50:35
I have a 1946 restored UTU. Oil pressure runs between 10 at idle to 25 at full throtle.How serious of a problem is this, tractor will not pull heavy work loads, maybe a hayride wagon.
guy hay
09-10-2006 20:36:36
 Re: Oil pressure in reply to jenks britt, 09-09-2006 11:50:35
I have a 47 utu and the oil pressure is always at 80 psi. Is that tooo much? Seems to run fine, no major leaks.
Curt Cooke
09-11-2006 06:25:54
 Re: Oil pressure in reply to guy hay, 09-10-2006 20:36:36
Too high oil pressure is not going to make for leaks. I would be concerned about excessive wear on the oil pump drive gear and the gear on the cam that drives it. I would also wonder if the regulator piston is stuck in place. Probably not a big deal but they were not intended to run that much pressure.
Jackmi
09-09-2006 18:24:09
A rule of the thumb. 10 pounds of oil pressure, for every 1000 RPM.
Curt Cooe
09-09-2006 18:10:47
25 is what they're supposed to have - you're OK. If you want more, a regulator adjustment screw is under the oil filter. You can change it, I wouldn't.
