Minneapolis Moline Tractors Discussion Forum
Ethan Help I want to build a UTU
roland withersp
09-07-2006 17:17:06
I have a utu with the single head I want to build it a little to do a little tractor pulling, not sure what to do with it short of a g motor, let me know and also what part no.s thanks Roland Witherspoon P.S. dont want to spend a fortune
Mopower
09-12-2006 16:53:35
 Re: Ethan Help I want to build a UTU in reply to roland witherspoon, 09-07-2006 17:17:06
Is your single block a red-nosed tractor? If so...maybe a lost cause because of the babbit bearings. If not, you can bore to and use a G crank. I believe welters sells the pistons for this combination. The oter cheap alternative is a 403 power unit.
jones in texas
09-08-2006 16:49:26
Since you have the older style one piece block and heads it might be a lost cause.Most if not all pullers use the later two piece blocks and heads.Good luck.
