Minneapolis Moline Tractors Discussion Forum
MM ZB 1955
C Davis
09-06-2006 04:12:20
Two Questions is the starter and generator to be black or painted same as the rest of the tractor. and is the glas in the head lights flat or domed also i need some of the linkage for the hydrolick controls
T.R.K.
09-06-2006 07:09:31
 Re: MM ZB 1955 in reply to C Davis, 09-06-2006 04:12:20
From factory the starter and generator were gold like the rest of the tractor. (It was assembled and then sprayed.) They sure look good black though.
The headlights on Granddad's 54 zb have slightly domed glass. 5-3/4" or so dia. lights.
I bet you need the rods and pivot that run from the rockshaft under the platform and up to the control lever beside the steering column.
Baucom sent me some parts for my ZB 1-800-658-2309. Don Rice was parting one 585-243-2617. I don't know what these guys have left as its been a few years since I worked on a ZB. Also check with Wendell Everett 740-922-3335 and Welters 417-498-6496.
C davis
09-07-2006 03:39:59
 Re: MM ZB 1955 in reply to T.R.K., 09-06-2006 07:09:31
Thanks for the info I have the rod and the piviot under the deck i need up to the side of the steering colum and the main lever. we have this tractor going back together we have had ever bolt out of it motor is done wheels are done painting block and castings this week end all other parts are painted this is the first mm for us we have jd and IH mainly
