Minneapolis Moline Tractors Discussion Forum
336 diesel
Jeff in SD
08-29-2006 22:08:15
I was wondering how I could get more cubic inches from my m5 336 diesel...will a crank from a ub gas work in a 336D ? looking for more power for tractor pulling next year....I thought maybe a stroker..
Chuck S.
08-31-2006 15:05:59
 Re: 336 diesel in reply to Jeff in SD, 08-29-2006 22:08:15
The 403 crank is a direct bolt in a 336 block. The 336 crank is the same for both gas and diesel. The 403 was used in G series gas tractor and as a power unit. The 403 is a 6in stroke and the 336 is 5in. You will need pistons that are 1/2 in shorter.
Jeff in SD
09-05-2006 13:01:00
 Re: 336 diesel in reply to Chuck S., 08-31-2006 15:05:59
thanks for the info chuck S....I better start looking for a 403
Chuck S.
08-30-2006 17:18:54
Your best bet would be a crank from a 403, if you con find pistons.
Jeff in SD
08-31-2006 12:47:53
 Re: 336 diesel in reply to Chuck S., 08-30-2006 17:18:54
Is a 403 a gas motor...what tractors had a 403..and will that crankshaft fit in a 336 block..I,m sure nothing is a direct fit.probably have to do some machining?
