Minneapolis Moline Tractors Discussion Forum
Sleeve Manufacturer
Fungus
08-28-2006 11:58:40
First off, my KTA is in need of some motor work. I plan on having the cylinders sleeved and bored back to standard. I was wondering who manufactures sleeves for old tractors? The machine shop was just asking if parts are even available!
This tractor has a 283ci motor with a 4.25" X 5" bore and stroke, the same as model U's.
Appreciate the help!
J Schwiebert
08-28-2006 17:58:01
 Re: Sleeve Manufacturer in reply to Fungus, 08-28-2006 11:58:40
I can not believe plain jane repair sleeves are that hard to come by. Also if you can find oversize pistons use them. did you price the fix per cylinder for installing a sleeve and the the sleeve? Where are you located? J.
Yugrotcart
08-28-2006 15:30:11
Hmmmmm mmm, know of a fellow in Flesherton who wanted to bore out his KTA. Problem was, you need a special boring machine as the cylinders are so long. Can't remember who he found that would do it, but it was real pricey, didn't happen. I know of two brothers up in Lindsay that have lots of old Minnies, they might be able to help you out somehow. Not sure of there names, won't be able to get a phone number for a few weeks.
Shoot me an email, and I'll get back to you ASAP.
Paul
Monte (MN)
08-28-2006 12:26:51
Try Darton Sleeves, look in their sleeve catalogue under repair sleeves.
dartonsleeves.com
Dieselbear
08-28-2006 15:42:37
 Re: Sleeve Manufacturer in reply to Monte (MN), 08-28-2006 12:26:51
Try LA Sleeves, send them an old one or the measurments and they will make it for you
Jerry Cent. Mi.
08-28-2006 15:51:44
 Re: Sleeve Manufacturer in reply to Dieselbear, 08-28-2006 15:42:37
Why not bore it and use 4 3/8 pistons?
T.R.K.
08-28-2006 19:08:41
 Re: Sleeve Manufacturer in reply to Jerry Cent. Mi., 08-28-2006 15:51:44
I had 3 U cylinder blocks sleeved back to fit standard pistons in the mid '90s. Cost was about $100 per hole, sleeve + labor. I'm sure it would be more now.
Overboring to 4-3/8 would work except the pistons in there now probably have the setscrew lock in them. The small end of the rod is wider for these pistons than the rod that works with the later full floating pistons. I only found this out after I had one set of blocks ready to go on the engine (I thought.) The rods can be cut down to work with the full floating pistons, but that is another machine operation that must be paid for.
