Minneapolis Moline Tractors Discussion Forum
G1000 hyd
schrockfarm
08-20-2006 18:59:02
We have a G1000 that we use for PTO work running a 15 in. 80 ft grain auger. It pulls hard and makes the tractor work...our 4020 cannot even do it. My problem on the G is that we boil oil out of the hyd vent. Is something wrong or what could be causing this??
J Schwiebert
08-25-2006 14:59:16
 Re: G1000 hyd in reply to schrockfarm, 08-20-2006 18:59:02
Refresh my memory. I need to look at my G-1000 book and I have it packed away. Put a candy thermometer and check the temperature. From just hydraulic fundamentals you have a major problem. Can you send me a phone number. J.
schrockfarm
08-26-2006 18:27:25
 Re: G1000 hyd in reply to J Schwiebert, 08-25-2006 14:59:16
Dave @ 574-633-4131
schrockfarm
08-24-2006 13:42:43
we drained the fluid and put fresh in... and yes it does make a difference if we do not load the tractor heavy. It does not appear to slip but who knows...it does have a good snap to it, is there another way to tell ? Thanks
Dale Hollen
08-21-2006 16:13:58
schrockfarm hope you find whats wrong. Got a vista that does the same thing when just using the 3 point. It also does it when using the pto. The 3 point is week, got a 5 bottom semi-
mounted plow it won't pickup very well. Maybe this well help with solving the problem. Thanks for any help.
duanekaufman
08-21-2006 07:49:17
Hi,
I've not heard of this happening before, but things to check:
1) Is your tranny fluid and hydraulic fluid the correct type and filled to the proper level(s)?
2) Is the PTO clutch slipping? Does the lever engage with a definite 'snap'?
If this overheating doesn't happen working it hard by pulling it (not PTO work), I'd continue to look into the PTO drive-train. Can you run the auger _without_ pulling the engine as hard (maybe without slipping the clutch?)
Another thought has occured to me...is it _oil_ that is boiling, or could you have some water in the hydraulic reservior?
Duane
spencer zellweger
09-12-2006 06:38:53
 Re: G1000 hyd in reply to duanekaufman, 08-21-2006 07:49:17
do you guys have any info on finding a 504 diesel motor. We have a vista g1000 torn apart with a cracked block. thanks for the help
