Minneapolis Moline Tractors Discussion Forum
335 ampli-torc
shebeliever34
08-18-2006 18:24:19
In low range, tractor loses forward motion. With ampli-torc engaged, everything works fine. Rebuilt engine clutch, and adjusted ampli-torc, but something seems to be slipping behind the engine clutch. Believe it to be ampli-torc related. Any help would be appreciated.
shebeliever34
08-21-2006 17:22:19
 Re: 335 ampli-torc in reply to shebeliever34, 08-18-2006 18:24:19
got cage out, is there any to check wear on ramps & springs,rollers average .003 under.were can i get parts
JK2
08-24-2006 05:32:27
 Re: 335 ampli-torc in reply to shebeliever34, 08-21-2006 17:22:19
Check the ramps for a groove across them. If there is one you can polish it out with a hand stone but it will take some time. The rollers and springs are available from Everetts @ 740-922-3335, Welters & likely several of the parts suppliers listed on the MM website.
John
ejr-IA.
08-19-2006 09:05:27
Your sprag ramp and roller clutch is propably bad in the low side.Parts are available.
