Minneapolis Moline Tractors Discussion Forum
JT starting crank assembly
Loren in MN
08-16-2006 06:23:07
Does anyone have a starting crank gear assembly for a JT Moline. Mine is broken and won"t turn the engine. Seems to slip inside the gear box. Thanks.
Loren in MN
08-17-2006 19:44:33
 Re: JT starting crank assembly in reply to Loren in MN, 08-16-2006 06:23:07
Thanks guys- Yes it is two gears and a chain. Turns out the pin holding the lower sprocket to the shaft is sheared off. Now I need to figure out how to get the gearbox out of the tractor without splitting the tractor.
T.R.K.
08-20-2006 18:02:16
 Re: JT starting crank assembly in reply to Loren in MN, 08-17-2006 19:44:33
If you can get the pin out of the upper sprocket you can probably pull the crank out the front and the whole mess will fall to the floor. It may take some heat and I think that pin is tapered. If so, you will have to drive from the small end.
Removing the radiator would help a lot, But there again you may have broken bolts to contend with.
Bryce
08-16-2006 06:29:14
I thought the JT is chain driven inside the crank box. Could you replace the sprockets and chain or is the wear too much for that?
T.R.K.
08-16-2006 06:28:41
I don't have a spare one, but I am 95% certain that gearbox is the same as MM used on the UTU series tractors. It just has two sprockets and a chain between them.
