Minneapolis Moline Tractors Discussion Forum
Carb on 1350
Greasey Hand
08-16-2006 05:10:49
Need a LP carb for a 1350MM 585 motor.
Thanks for now.
The carb on this one is broke, The neck that goes to the regulator.
shinnery
08-27-2006 21:37:37
 Re: Carb on 1350 in reply to Greasey Hand, 08-16-2006 05:10:49
I thought for a while I might have had one, but I dug it out today and it is 2 15/16" on the mounting holes and 1 5/8" bore. way to big for my M670 but too small for you.
Bryce
Chuck S.
08-19-2006 08:01:48
MM built a lp G1350 they had a 504 in them. The manifold you have is for an 800. Call Matt at Motec.
PGpower
08-17-2006 05:54:54
I good place to start is to call Matt at Motec Engineering. He deals with Moline carbs, etc. Phone number is 765-963-6628 If he doesn't have what you need, he might be able to point you in the right direction.
Greasey Hand
08-17-2006 05:41:19
 Re: Carb on 585 cu. in. MM in reply to Greasey Hand, 08-16-2006 05:10:49
Not my tractor, The tractor is a G1000 LP,
The owner put a different exhaust manifold on it & a diff. intake. A mutch bigger one, That is what he told me it was off of.
They done this years ago, Im no big yellow dog expert, He had taken the carb & regulator of & dint bolt the reg back up to the nanifold bracket, broke off the neck to the carb.
Need a carb, Number on tag 1774. He is the one you want to tell the 1350 is a Diesal.
He wouldn't beleve you if it was infront of him.
Was there a 585 LP? If so I need a LP carb, Its
mounting hole spacing is 3 5/16" throught is 1 15/16" Hope some one can help on this.
What?
08-16-2006 15:43:21
An LP carb on a diesel??? Thats a new one to me.
