Minneapolis Moline Tractors Discussion Forum
UTU Hand crank box
Kansas Coy
08-15-2006 09:09:38
hey guys. i just purchased an old utu and the hand crank shaft is free and turns but it will not turn the engine over. is there a chain or something in that small box that is attached to the shaft that could be broken?
Bill Becker
08-16-2006 11:09:23
 Re: UTU Hand crank box in reply to Kansas Coy, 08-15-2006 09:09:38
I've got a U with the same issue. In order to replace the pin, you'll have to remove the front end.
Kansas Coy
08-17-2006 07:56:17
 Re: UTU Hand crank box in reply to Bill Becker, 08-16-2006 11:09:23
Is there any other option other than removing the pedestal?
T.R.K.
08-17-2006 18:51:57
 Re: UTU Hand crank box in reply to Kansas Coy, 08-17-2006 07:56:17
You may can split the box either by reaching past the radiator or reach up from underneath to remove the nuts from the bolts. to get the shaft out you have to split the box whether you remove the pedestal or not. Drive out the pin in the gear on the shaft, then you should be able to pull the shaft from the pedestal. You can probably replace the chain or whatever without removing the shaft.
Larry O.
08-15-2006 11:09:21
Yes. There is a chain and 2 sprockets. A pin in the sprockets could be sheared too.
