Minneapolis Moline Tractors Discussion Forum
Need reassurance with reassembly
mike mcmurray
08-13-2006 12:32:50
Sorry if this is a stupid question, but I am looking for reassurance. After adding new standard rings to the pistons of my MM RTU, and properly staggering them (according to manual), I used a ring compressor and installed them into the cylinders (which were honed prior to this assembly). I had to lightly tap them (block of wood and hammer) to get them all the way in. (I thought they would go in easier since the bore, cylinder and compressor were all oiled up). I then added the gasket and dropped each cylinder block into the case. I next added the rocker arms (with each valve tappet backed off all the way), and then slightly tightened the block bolts. For each connecting rod journal, I added new standard bearing shells. I greased them up and torgued the bolts to about 50 lbs, added the metcal clips and cotter pin. (please keep in mind that I never removed the crankshaft and each rod was reassembled to the proper locating)). WHere I need reassuarance is the following:. 1st:, would I know (with any one of the five senses), if a piston ring was not seated properly within the cylinder ....would I hear a terrible grind, etc when I hand cranked it over..... .????? THe pistons had soaked in kerosene for over a week, and I made sure the ring grooves were both cleaned out and within tolerance according to the manual specs. I do not hear anything when I hand crank it (no grinding, etc.....Is quiet good!!!!!) I also poured a little oil in the top of each cylinder just to make sure I was not scoring the interior of the cylinder if I did indeed do it wrong. My second question is: What exactly should it feel like when hand cranking it....assuming I attached the connecting rod and new bearings correctly, should it smoothly crank over. I do feel a "slight" (I mean very slight) resistance when cranking it by hand. Is this normal? If it was binding or improperly assembled, WOULD I DEFINATELY KNOW IT? WHen I hand crank it, it feels the same as it did when I first got it.....Also, with the pistons in, should it be very difficult to crank it by hand using just the pully (without the crank arm). I do not have the cyinder head, crank case cover, etc on yet. The valves are still backed off all the way and there is no oil (except for what I lubed up) at this point. Sorry for the long post, but I appreciate any and all responses. Have a nice weekend. Mike McMurray
Alan K
08-14-2006 22:40:20
 Re: Need reassurance with assemby in reply to mike mcmurray, 08-13-2006 12:32:50
That sounds like you did just fine to me. You will feel a slight drag cranking it by hand, that is normal. The main concern on the R-Z engines is the ring groove at the top of the cyl. If you installed new rings and cranked it over with no problems it should be just fine.
Curt Cooke
08-14-2006 07:31:00
 Re: Need reassurance with reassembly in reply to mike mcmurray, 08-13-2006 12:32:50
Sounds good to me. It always takes the butt end of a hammer to get the pistons in. Ring spacing is over-rated; research has shown that they move around until they find a spot that they are most comfortable. Turning the engine should be smooth but not effortless. Sounds like you have it under control. Proceed.
Curt
