Minneapolis Moline Tractors Discussion Forum
Need a UB starter Motor
Big Kahuna
07-28-2006 10:59:07
Help! Help!
I need a UB starter motor. Any ideas?
please help
Thanks
tanya gregory
07-29-2006 11:53:54
 i need a starter for a 57 moline tractor in reply to Big Kahuna, 07-28-2006 10:59:07
If anyone knows where i might locate one would be great. i have been all over this internet lokking for my father-in-law. please help me!!!!! !!!
Marvin Henderson
07-29-2006 06:43:40
 Re: Need a UB starter Motor in reply to Big Kahuna, 07-28-2006 10:59:07
I have one complete and operational for 100.00 plus shipping Thanks
Marvin Henderson
08-01-2006 05:39:59
 Re: Need a UB starter Motor in reply to Marvin Henderson, 07-29-2006 06:43:40
Yes i am sure been around MMs for a long time
Big Kahuna
07-29-2006 08:59:41
Are you sure you have the right one?
I have been all over looking for one.
1107605
or
1107659
12 volt
old
07-28-2006 20:59:42
Have you tried this site and or valuebilt. I know the catalog I have has a list for starters for the UBE and UBC not sure if they are what you need
schrocky
07-28-2006 19:12:10
I have one off of a diesel, I am not sure which you have or if they are the same... can anybody answer that ?? I know it needs to be rebuilt but I think I know an amish guy who would tackle it. I would want to send it there and have him look at it if you think it would work for you.
shinnery
07-28-2006 21:40:37
 Re: Need a UB starter Motor in reply to schrocky, 07-28-2006 19:12:10
The diesel starter probably won't fit. My repair manual shows 10A2999 or Delco 1109236 for the diesel and 10A3749 or Delco 1107605 for gas t. fuel and LPG. The diesel starter shows to mount with 3 studs while the others mount with one pointed end bolt in the side. Are you sure yours is unrepairable? When I got my UBU-LP it needed help and I took the starter apart and found it had thrown the solder from the communtator where the armature wires attach. I got a big soldering iron and reflowed the solder and it has worked for years, If I have to do it again I will probably find some low temp silver solder to see if that works better.
Bryce
Big Kahuna
07-29-2006 09:09:18
 Re: Need a UB starter Motor in reply to shinnery, 07-28-2006 21:40:37
The part number has to be 1107605 or 1107659
not diesel either.
My end plate is busted and the part that holds the arm to the brush is on it. the communtator looks really bad as well.
Thanks for the help
old
07-29-2006 11:58:29
 Re: Need a UB starter Motor in reply to Big Kahuna, 07-29-2006 09:09:18
Just looked in my catalog I told you about in my other post and valuebilt has them
