Minneapolis Moline Tractors Discussion Forum
3 5/16 diameter shaft?? Rear axle?
Tyler-MO
07-25-2006 11:51:01
I'm trying to repair a two-way integral plow that uses a 3 5/16" diameter x 33" long solid steel shaft that the plow pivots on. The original is broken and I need to find a substitute for it.
I intend to use an tractor rear axle shaft for this purpose. Can anyone out there tell me of any tractor that used this size axle shaft (it can be longer than 33" but not shorter).
Thanks for any help provided!
Tyler in Missouri
IBorange in TX
07-25-2006 20:31:55
 Re: 3 5/16 diameter shaft?? Rear axle? in reply to Tyler-MO, 07-25-2006 11:51:01
Take the parts to a machine shop, they can either weld the shaft together or mill a new one. I don't think a tractor axle will work because of the tempered ends. Good Luck.....
