Minneapolis Moline Tractors Discussion Forum
Steering
P C
07-21-2006 15:49:39
1946 UTU Turns To The Right Just Fine
Will Only Turn About 1/4 to The Left.
Any Ideas????
SWMolines
07-21-2006 19:45:01
 Re: Steering in reply to P C, 07-21-2006 15:49:39
Could be a tapered roller bearing has gone out on the worm gear causing it to bind up.
T.R.K.
07-21-2006 19:26:27
Is something jamming the sector gear, or a broken tooth? You may have to remove the radiator and the top cover over the steering gear to look inside. A bit flake of rust in the right spot will be enough to cause problems.
One thing you might try first is to jack the front up and try turning it then.
Another thought: Does it have one of those aftermarket gear reductions/anti kick back devices under or behind or part of the steering wheel? I have only seen a few of them but if you have one your problem may be in it.
