Minneapolis Moline Tractors Discussion Forum
carb and plow Questions
newtothisgame
07-17-2006 19:15:45
i have a 1950 zau and the tractor wont idle down when i screw the screw out and i dont want to screw it in cuz it gets to rich of a mixture or is that the only way to do it I also have a 2X14 moline plow on rubber and the furrow wheel and rim is shot is where do you find a rim and tire for the back do i have to find an old rim off of something also is it true that those moline plows are just about the best ones ever made some old farmers said nothing pulls like a moline plow
Alan K
07-19-2006 21:05:44
 Re: carb and plow Questions in reply to newtothisgame, 07-17-2006 19:15:45
I may have some plow parts for you, Ill take a look. They were one of the few plows that had actual clearance when they were out of the ground. but any two bottom is hard to get to pull straight in some soils. My dad always said years ago...oliver made a plow..they were about the only one who made a good scouring one.
T. R. K.
07-17-2006 19:18:55
The idle speed screw is on the throttle lever, near where the governor link hooks on. Its on the back side, between the carburetor and the engine. Backing the screw it out should slow her down. It sounds like you are adjusting the idle mixture screw.
