Minneapolis Moline Tractors Discussion Forum
220 in an R
person
07-17-2006 10:24:09
how much work is it to put a 220 motor in an R what has to be changed any help would be great
BLT
07-17-2006 14:56:51
 Re: 220 in an R in reply to person, 07-17-2006 10:24:09
I have an R that is rigged this way, Mopower is correct, you'll have to use the R flywheel and clutch, also the starter ring gear. the ring gear is too big, so I put some spacers around it and welded it to the flywheel in about 12 different spots. It sure makes a nice 3600 lb puller.
Mopower
07-17-2006 14:02:51
Yes this can be done using an R flywheel. i believe you may need a different ring gear and the water ports on the new engine do not line up with th radiator, but you could rig something up.
