Minneapolis Moline Tractors Discussion Forum
Battery
Newtothisgame
07-05-2006 19:40:55
would putting a 12v battery in a 6v system make any diffence in how a tractor would run or would the only differece be that it turns overfaster charges slower and lights changed
yousesteers
07-07-2006 19:17:18
 Re: Battery in reply to Newtothisgame, 07-05-2006 19:40:55
there is a topic of this on minneapolis-moline.com the topic is generator for rtu it has a lot of different ways of changing to a 12volt sysem
jones in texas
07-06-2006 14:29:29
I have changed over a number of tractors to 12 volt battery and chargeing systems. normally you can use the 6 volt starter as it spins faster and starts the engine much faster resulting in less wear and tear . Imstall a resistor on coil or replace with a12 volt coil .
rowdy33
07-06-2006 04:10:09
Alot of shops have the ability to convert the charging system. Our 335 and a mower was don. No problem. After that you simply change all the light bulbs to 12V. Not complicated at all.
newtothisgame
07-05-2006 20:29:42
the tractor is a 50 zau
old
07-05-2006 21:33:09
 Re: Battery in reply to newtothisgame, 07-05-2006 20:29:42
Can't say much on that tractor but chargering systems are chargeing system and all work the same. So if you don't go to a ull 12 volt system you will have a battey that doesn't charge more then maybe 8 volts which will kill a 12 volt battery. I would either switch to a full 12 volt system or fix the problems with the 6 volt system. I've never had a tractor as that one but I have had a couple RTUs which aren't much diffderant
old
07-05-2006 20:08:11
Depending on the tractor etc it could cause big problem. You could burn up the coil or have it explode, yes they will explode and it sounds like a shotgun going off when it does. Also if the chargeing system is set up for 6 volts the battery wil never charge up. Other then that it works ok and theres 1000s of tractors that have been switched over to 12 volts but alternators have been added and resistors also to keep the coils form going bad
