Minneapolis Moline Tractors Discussion Forum
Floating the valves
Floater
07-05-2006 15:29:11
Does Anybody out there pull a ZA (or tractor with a ZA motor) with higher than stock rpm have a valve floating problem? What is the highest rpm's that can be run? Is there any other valve spring that can be put on to get up to 3200 rpm's
Thanks Floater
john jones
07-06-2006 19:17:47
 Re: Floating the valves in reply to Floater, 07-05-2006 15:29:11
My suggestion would be to double up the spring tension, put a bigger jet in the carb, tighten the valves so they are not loose, put the hottest spark plug in that you can find, get an electronic ignition with a hot coil, new firestone tires and take as much weight out of the front as you can as the Z's were nose heavy and go out and have fun.
J.J.
