Minneapolis Moline Tractors Discussion Forum
335 ampli torq
John Scott
06-30-2006 04:56:37
Does anyone know how to adjust the ampli torq on a 335. Mine will jump out periodically.
Thanks
T.R.Kelvin
06-30-2006 19:15:04
 Re: 335 ampli torq in reply to John Scott, 06-30-2006 04:56:37
I'm assuming that its jumping out of high range. There is a plug (has a bolt in the middle) on the right side of the bell housing near amplitorque lever. Don't completely remove the bolt, the t-bar will drop in the case.
To tighten the clutch use a screwdriver or something to pull the lock pin and another bar to turn the collar. Only one notch or two should do it.
some 335s or 445s don't have the plug. The I/T manual shows where to drill the hole.
