Minneapolis Moline Tractors Discussion Forum
5 star gov question
moli
06-28-2006 08:17:56
I built an adapter plate so i could put this gov on my u so i could pull in div 2..I couldnt get the original u gov to turn the 1680 rpm that im allowed.The 5 star motors governed speed is 1650.Figured if i put it in I could get near what i needed..But i can only get 1500 outta the 5 star gov..Can i pull out some fly balls and get it up where it needs to be.Theres 4 of em evenly spaced so i cant pull out just one,most that can be taken out is two.If this is too much i can adjust rpm down..Will it work or is there a better way without getting into another gov???
Augie
06-28-2006 09:28:58
 Re: 5 star gov question in reply to moli, 06-28-2006 08:17:56
The stock governor should give you 1680 and more just by turning the screw. I'd be looking real close at the linkage between governor and carb.
