Minneapolis Moline Tractors Discussion Forum
445 Remotes
Bog
06-28-2006 05:09:08
I have a 445 utility with a 3point hitch and one remote on the hyd system. I was wondering if it is hard to add a second hanldle to the system so i could have 2 remotes. I see the casting has the two more pipe plugs to add the hoses for the pioneer couplers. If this is possible what do i need? (Handle, spring, thimble) If you guys have any ideas please let me know.
ROWDY33
07-06-2006 04:41:55
 Re: 445 Remotes in reply to Bog, 06-28-2006 05:09:08
QUOTE
" i would assume the spare ports would be for the unused lever..kinda impossible for me to ad a remote with the loader on mine but ive seen it done.
It is possable Gregg.
Apearantly you are using the tractor's pump that powers the power steering and obvous the remolt hydro system. What can be done is add another pump and valves independent from the tractor's system. Their is a plate on the left side behind the PTO lever. Remove that and install the pump. You engage the PTO to engage the pump. The pump is also quite larger. The valves are mounted on the right side of the loader's fraim. The oil resivore in in the loader fraim also.
Gregg in ohio
06-28-2006 12:29:10
my 445 has three levers by the seat,,one for three point outside lever and two others..i have a loader so those are taken..if you got a spare lever doing nothing i would assume the spare ports would be for the unused lever..kinda impossible for me to ad a remote with the loader on mine but ive seen it done..gregg
1755
07-03-2006 09:53:43
 Re: 445 Remotes in reply to Gregg in ohio, 06-28-2006 12:29:10
We aded a Im going to call it a spliter that is not right but it has your 2 lines from one lever going to it and then it has 4 come out with a lever sow you can pick witch set you want to use our Jet Star 2 has a loader and a blade with a 2way cylender on it set it up so the bucket is on one lever and the rear hookups and the loader up & down is on the other start tractor rase loader switch lever locking loader in that spot then use the lever for blade or whatever
