Minneapolis Moline Tractors Discussion Forum
LP CARB
Rdd
06-27-2006 03:11:30
I have a U propane that has been sitting for about 10 years and was stuck. I got it unstuck put new coil, plugs,points and condenser and it started right up. But it idle fine but when you open it up or drive it cuts out bad till you pull the thottle back. Any help would be great. Yes it still has the Ensign regulator and carb.
STEVE HARDEN
06-27-2006 21:31:52
 Re: LP CARB in reply to Rdd, 06-27-2006 03:11:30
MAKE SURE THAT YOUR RADIATOR IS FULL TO WARM THE FUEL THAT MAY HELP
START, LEAVE CHOKE ALL THE WAY OUT TILL IT STARTS TO WARM UP. I START MINE ON VAPOR USE LIQUID ONLY IF I WORKING HER.
DO YOU KNOW IF IT WARMS UP? PERHAPS SOMEONE HAS TAKEN THE PULLED THE THERMOSTAT.
JLM
06-27-2006 12:34:47
I have a GB Lp. Just a wild guess... I would say you are running lean. The engine is not getting gas. In a hard pull the LP needs to be warmed up....running on liquid fuel.....and plenty of hot water circulating to preheat the fuel. Check for stopped up filter, fuel lines, valves, etc.
