Minneapolis Moline Tractors Discussion Forum
5 Star vs. M5 gear ratios
PB
06-25-2006 08:53:23
Anybody know the mph of an M5 4th gear?(on 38's) I think all other gears are the same as a 5 Star, right?
Captainhookerus
06-26-2006 10:40:59
 Re: 5 Star vs. M5 gear ratios in reply to PB, 06-25-2006 08:53:23
The M5 is different than the 5Star. What was done was 3rd gear in 5Star became 4th gear in the M5 and a new set of gears and a new speed between 2nd and 3rd in 5Star was put in M5. If you put M5 gears and shifter fork in a 5Star the 3rd is 4th and 4th is 3rd with out changing to a M5 shifting cover. 4th low in old 5Star was a good speed but amplitorque didn't like extended running in low. So after all this long explanition 3rd high in a M5 is the same as 4th low in a 5Star
Tex Aggie
06-25-2006 16:33:21
I have both a M5 and a 5 star. The 5 star is faster by prob. 4mph. I know in 5th road gear, it is a lot faster feeling.
ejr-IA.
06-25-2006 15:45:29
Out of the book 1500rpm with 15.5x38 4th gear high range 7.31 low range 3.84
Harrold Rhodes
06-25-2006 09:09:12
Using a memory thats fuzy after nearly 50 years, the 5 star was 10 mph + and m-5 was around 7.5 in 4th
