Minneapolis Moline Tractors Discussion Forum
Oil Filter
ZinMN
06-22-2006 12:55:14
i just changed my oil filter on my 50 Zau moline and when i reasembled it and put oil in and started the tractor oil gushed out where the bolt goes against the shell cover of the oil filter the copper or brass piece of metal that sits between the bolt head and shell inst sealing any more what do i do to seal that off
Alan K
06-23-2006 22:31:11
 Re: Oil Filter in reply to ZinMN, 06-22-2006 12:55:14
Make sure there arent any cracks at the end of the filter shell. That does happen on those. A good nylon washer will work also I believe.
J.Wondergem
06-22-2006 15:20:22
If it is copper, you can heat it up red hot and drop it into a bucket of cold water. It will puff the copper back up, so it will seal again.
