Minneapolis Moline Tractors Discussion Forum
425 head gasket
MM~GIV
06-19-2006 17:43:45
Napa can not find a number for the head gasket can someone give me the fel-pro number for the head gasket for a 425 that is in a G VI ? thanks
Glen in TX
06-23-2006 12:15:55
 Re: 425 head gasket in reply to MM~GIV, 06-19-2006 17:43:45
Try Lubbock Gasket.
MM~GVI
06-20-2006 07:39:19
It is a 1969 GVI with a Lp gas 425 B-6 # 16101519 with a 4.5 bore . Thanks
cAPTAINHOOKERUS
06-20-2006 14:23:28
 Re: 425 head gasket in reply to MM~GVI, 06-20-2006 07:39:19
The serial number you have is an engine number for a 1960 GVI. If your block number is 10A149A then you have regular blocks bored out to 4.5. If they are anything else you should have a 4.625 bore. E-Mail me [email protected]
Captainhookerus
06-19-2006 21:06:08
Let me know what your block number is and I will send you some gaskets. Need to know for sure if it is a gas or diesel and bore size
flamefighter
06-19-2006 18:32:20
The napa number for a 425c which would be in a 905 after a certain serial number is hs3814 for a set or ch3814 for single gasket. Would be different for gas or diesel. Herschel-Adams in Indianola Iowa 1-800-247-2167 List a set for a 283 Gas. Part number A523787. You would be one jug short. Maybe they could help. I would think that agco dealer would still be able to get them. Good luck.
ejr-IA.
06-19-2006 18:24:45
Gas or diesel a 504 gaskett may work for you.Gas Clevite no. HS3814 diesel no.HS3813Y then theirs a heavy duty no.CH3813.
