Minneapolis Moline Tractors Discussion Forum
Z and R pistons
Steve Browning
06-19-2006 14:07:15
Has anyone tried to run R pistons in a Z for higher compression. I have A Z with a extra set of r pistons which have a high dome on them. I would like to run. I am afraid of having to much compression with my high compression head.
The REAL Kelvin
06-19-2006 18:35:58
 Re: Z and R pistons in reply to Steve Browning , 06-19-2006 14:07:15
The R pistons are too tall to work without shims or stacking block gaskets. You would be better off to try an LP head or something.
flamefighter
06-19-2006 17:55:48
Hi. What head number do you have? If you are going to use the r dome pistons the only head you can use is the RE 226 c I think. The 10 a2648 and propane head 10 a2647 I believe would hit the piston dome. I may be wrong but would think that is the case. I would not worry about to much compression on the 206 engine. We have bored them out with pistons that have a higher pin height and ran the propane 10 a 2647 head with no problem.
