Minneapolis Moline Tractors Discussion Forum
Rebuild or replace an engine?
Jim Calhoun
06-15-2006 22:53:49
I have a ealy 1950's model U that has developed a severe knock also most likely has a broken ring.
I have a good used engine in a power unit that I could use to get this tractor up and going so I am not totally stuck, but I needed an opinion or two.
Is it easier to disassemble the engine and do a rebuild or is it easier to split the tractor and do the swap?
If the engine can be rebuilt without splitting the tractor that might be what I am leaning toward. Any and all suggestions and advice will be appreciated!
BCnT
06-16-2006 08:11:57
 Re: Rebuild or replace an engine? in reply to Jim Calhoun, 06-15-2006 22:53:49
not sure about your situation but i always got more time than money...do the swap and then rebuild the old engine for a spare as cash allows.
ILL John
06-16-2006 05:36:21
Jim, Just a thought, if it's knocking, it could mean taking the crank out to be turned, have to split the tractor to do that anyway.
Jim Calhoun
06-16-2006 08:38:27
 Re: Rebuild or replace an engine? in reply to ILL John, 06-16-2006 05:36:21
If I have to split the tractor anyway I might as well do the swap.
